Senaste nytt:
× Malossi MHR Teamspeed II 86cc
× Malossi MHR Gearbox Cover
× Malossi MHR Packningar
× Polini Evolution 2 Racing Bell
× Stage6 Racing 30mm Manifold
× Stage6 Racing Vikthylsor
× XSH Wig
På gång inom kort...
× Vev...
Planer / Funderingar
× Mer trim...?!
× Lacka Ram
× Polera Fäljar?
Setup:
Malossi MHR Portat Block | High End Tuned by −=DooD=−
Malossi MHR Teamspeed II 86cc | High End Tuned by −=DooD=−
Malossi MHR Teamspeed II 77cc | High End Tuned by −=DooD=−
Malossi MHR Teamspeed II 70cc | Tuned by Malossi MHR
Malossi MHR Eprom Digital
Malossi MHR Multivar
Malossi MHR X-Kevlar Belt
Malossi MHR Rear Pulley System
Malossi MHR GDF Spring
Malossi MHR Delta Clutch
Malossi MHR Black Springs @ 9000 rpm
Malossi MHR Safety Bell
Malossi MHR Malossi HTQ 13/44
Malossi MHR Torque Controller
Malossi MHR HAT 3.5g
Malossi MHR HAT 3.8g
Stage6 Racing 2.6g, 3.0g, 3.5g, 3.9g
Stage6 Racing Team Rod85
Stage6 Racing Dual Layer Klein
Stage6 Racing Spacer Kit
Stage6 Racing Vforce3, Carbon
Stage6 Racing CNC Disc
Stage6 Racing Munstycken Set
Stage6 Racing Lågfartmunstycken Set
Polini Sekundär 17/40
XSH 28mm Wig
Insug By −=DooD=−
NGK Racing Tändkabel
NGK Racing BR10EIX Irridium
Denso IW34 Irridium
Kiesler 4mm Reedspacer
Kiesler Subframe, Sprint-mode
Mikuni TM28ss Flatside
Yasuni C30 Black Edition
Säkerhet:
Metradisc 220mm Fram
Metradisc 190mm Bak
Stage6 Racing Bromsok
Stage6 Racing Tempgivare
Reich Cirkulationspump
Styling
TNT Nudebar
TNT Höjningssats 50mm
Fournales Chrome 325mm
Kiesler Evo Racing Bakstänka
Polerade Detaljer
Resulat:
Dynojet - MotoSpeed
19.02 HK SAE
19.43 HK Uncorrected
Dynojet - ABG
19.13 HK SAE
19.8_ HK
Teamspeed I 70cc Tuned By −=DooD=−
Toppfart: 130.8 km/h
Toppfart Sprint: ---.- km/h
Sprint 201m: 11 s
Teamspeed II 70cc Tuned By −=DooD=−
Toppfart: 137.4 km/h
Toppfart Sprint: 113.0 km/h
Sprint 201m: 8 s
Teamspeed II 70cc Tuned By Malossi
Toppfart: ---.- km/h
Sprint 201m: - s
Teamspeed II 77cc Tuned By −=DooD=−
Sprint 201m: - s
Teamspeed II 86cc Tuned By −=DooD=−
Sprint 201m: - s
Filmer
Hänvisar till tråden "DooD's Videoklipp..."
http://forum.moppenet.com/showthread.php?t=63279
Kommentera gärna!
Update (57)
Motorn färdigbyggt och ska hängas på plast inom kort!
2008-02-01
2008-02-01
2008-02-01
2008-02-01
Update (56)
Original tiderna på BB 77cc och 86cc
77cc 194/131
86cc 186/126
Update(55)
Ts Big Bore 86cc, Drevkåpa, Evo 2 Klockan, XSH Wig, Insug, Packningar, Hylsor
2008-01-30
86cc vs 77cc
2008-01-30
77cc vs 86cc
2008-01-30
2008-01-30
2008-01-30
2008-01-30
Update(54)
Pappsen fixa en VIP-hylla.
2008-01-13
Update(53)
Nu har cylindern anlänt! Vissa visste redan om. Mer saker tittar in så småningom.
2008-01-11
2008-01-11
2008-01-11
2008-01-11
2008-01-11
Update(52)
Liten tjuvkik på motorn som den är just nu...
2007-12-14
Update(51)
2007-12-13
cylinder och lite annat...
Här finns det mkt o hämta
2007-12-13
Update(50)
Va händer här då?? Konstigt de ser ut?!
2007-12-11
2007-12-11
Resultatet... Ny fyllnad vid reedfästet och reed/spol.
2007-12-11
2007-12-11
Fyllde även igen överportade områden på spolarna.
2007-12-11
Update(49)
Motorn klyvd och alla packboxar o lager här o där ska bytas.
2007-12-09
Update(48)
Kommer eventuellt testa den för o se om de är ngt drag i den.
Pro Race 8T
2007-11-13
Update(47)
Ska försöka få upp gastemperaturen i headern.
Update(46)
Kunde inte låta bli att fingra på den lite till. Nu är portarna nästan identiska med ts2T cylindern! Avgasporten är de enda som skiljer.
Filade på den lite till ytterligare men uppdaterar inte tråden officiellt.
2007-10-30
Portarna är 100% speglade nu.
2007-10-30
Update(45)
Var i väg till Mangee o köpte mig ett rör.
Carbon/Kevlar Edition
2007-10-06
Åkte över till Freddan_ och hämtade en ny sadelbox samma dag som ja var till Mangee.
Boxen och röret monterat.
2007-10-06
Update(43)
2007-09-28
Malossi har graverat in ett "T" på cylindern
2007-09-28
13mm nållager
2007-09-28
Update(40)
Västerås Sommarlovs Meet
2007-08-18
2007-08-18
2007-08-18
Update(39)
DooD är på Borås Meet 2007
Väntar...
2007-08-11
DooD vs Litta
2007-08-11
Update(37)
Tog mej en stund i bänken som fanns på plats Västerås Sprint Weekend 2007
2007-06-30
Dyno!
2007-06-30
Bänkreslutat. Pickupen vart riktigt fin.
19.02 HK SAE
19.43 HK uncorrected
2007-08-19
2007-08-19
Efter stunds justerande i bänken hade freddans zip svårt att hänga på 201m.
2007-06-30
2007-06-30
Update(36)
Gjorde ett litet experiment med gpsen för o bevisa cykeldatorns nogranhet. Tejpade fast den på styret.
Har bilder och videoklipp även vid högre hastigheter men bilderna blev så skakiga.
Man är tvungen att hålla så jämn hastighet som möjligt pga. fördröjning i gpsen.
2007-06-16
2007-06-16
Update(35)
Testar lite nya teorier på portningen. Fixade även till symmetrin på dem så de ska vara så lik varandra som möjligt.
Rättade även till cylinderns samtliga portar. Resultatet visar sig snart. Det kan antingen bli bättre eller sämre. Hålen på sidorna är igenfyllda nu.
2007-06-13
2007-06-13
Klar! Nu ska den bara hängas på plats igen.
2007-06-14
Update(33)
Bilden tillängad stejFaan.
2007-05-20
Fick ordning på tm förgasaren Felet var nålen. Så bytte till en med fetare koning i början.
2007-06-15
Update(30)
Lite olika kolvar....
Från vänster: MHR, Pro Race och Manston
2007-04-15
Update(29)
Nya drev har anlänt. Ovanliga drev som är Polini Sekundär 17/40
Kan skapa en rad olika kombinationer nu.
STD Primär 13/52 + STD Sekundär 14/43 = 12.29
STD Primär 13/52 + Polini Sekundär 17/40 = 9.41
Malossi Primär 13/44 + STD Sekundär 14/43 = 10.40
Malossi Primar 13/44 + Polini Sekundär 17/40 = 7.96
2007-04-10
Update(28)
Gjorde mig ett lite rejälare insug i stål.
2007-03-26
Update(27)
2007-03-15
Ungefär så här kommer den se ut med Kieslersubframen.
2007-03-02
2007-03-02
Update(26)
2007-02-24
2007-02-24
Update(25)
Motorn provmonterad o väckt den. Den startade utan problem.
2007-02-16
Update(24)
Fournalesbakdämparen har kommit nu äntligen.
2007-02-15
2007-02-15
Update(20)
2007-01-25
2007-01-25
Update(15)
Stage6 PWK28, Mikuni TM28ss, Keihin PWK28
2007-01-02
Den slutliga finnishen på blocket. Resutatet är klart godkänt. Ytan matt o mkt jämn.
2007-01-02
Update(14)
2006-12-30
Update(13)
2006-12-23
Bilder på moppen
2008
Kommer inom kort.
2007
2006
2006-08-11
MVH Erik as −=DooD=−
Copyright© 2006-2008 By −=DooD=− Tuning
